Tagged: ansys-mechanical, BAJA SAE, chassis, Front wheel bump, fsae, modal, roll-cage, Student Team
June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video shows how to carry out a front bump test and a modal analysis of a chassis in ANSYS Mechanical. You will learn how to determine the resulting stress and deformation due to various forces on the chassis. For questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
