At ANSYS 8.1 it is supposed to be possible to postprocess velocity and acceleration in POST1 after a full transient analysis using commands such as PLNS,V,X or PLNS,A,X. Why doesn’t that work for me?
March 17, 2023 at 9:00 am
FAQParticipantThe velocities and accelerations are not written to the results file by default. They must be requested with OUTRES,V,1 and OUTRES,A,1.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
