Are there any ANSYS Mechanical APDL examples with the TCC (thermal contact conductance coefficient)?
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 248586.pdf
2. 248586.zip
