Are PSD results correct if the following message is used during the solve. “One or more diagonal terms of the modal covariance matrix (i.e., when mode i = mode j) is negative. The 1 sigma results may be incorrect as a result of the input PSD curve being improperly represented.”
January 25, 2023 at 7:34 am
FAQParticipantNo. Some recommendations are: 1. Check the PSD input curve fit with PSDGRAPH. PSD input frequencies should not increase by more than one order of magnitude per point. 2. Take the square root of the integral of the response PSD [RPSD in post26] and compare this quantity to the Post1 1 sigma value. They should be equal. 3. Do not input a curve with very low frequency values, far below the natural frequencies of the structure.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
