ANSYS SpaceClaim: I’m using a drawing sheet to create a print for a part and am wanting to place a hole table in my drawing. In the hole table it will list a tapped hole with the drill size for the tap. I am wanting to remove the information about the tap drill. I feel that this information isn’t needed and takes up valuable space. How can I edit the table to remove this information.
June 5, 2023 at 7:05 am
FAQParticipantTwo options that could help are: 1. The text in the description field can be edited to delete unwanted values/information in the hole table. 2. Extended hole information will only be shown if a hole is “smart”. Right clicking on a hole and choosing remove association will remove the smarts of the hole and you’ll simply get a diameter in the description field.
