ANSYS SpaceClaim: I´m missing tabs for the part libraries Tracepart and Cadenas which were available with former SpaceClaim-Versions. Is there a special set-up required or are they just skipped.
June 5, 2023 at 7:05 am
FAQParticipantThese are still in the Insert tab, you need to expand the “Standard Part” menu under Part section. Please refer attached image which shows these options.
