May 15, 2023 at 8:32 am
SolutionParticipantWith SpaceClaim, it is easy dealing with geometry creation. In sketching, you have Mirror Line feature for creating symmetric sketches. You can also give dimensional references in Cartesian or Cylindrical CS from any specific feature. Keywords: Pull,Move,Sketch, Mirror Line
1. 2052823.mp4
2. 2052823.zip
