May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim has variety of features for creating geometry from scratch. In sketching, you can use various tools for creating base sketch. You can then use 3D geometric operations for creating the final geometry. Keywords: Pull,Move,Sketch
1. 2052825.mp4
2. 2052825.zip
