May 15, 2023 at 8:32 am
SolutionParticipantIn this attached video, it discusses about creating geometry as shown in previous part. Additionally, we will see how to create holes in the plates and pattern them using Move command. Keywords: Pull, Assembly, Move, Sketch
1. 2052814.zip
2. 2052814_Captions-EN.mp4
