May 15, 2023 at 8:32 am
SolutionParticipantIn attached video, it discusses about how to create a final geometry by generating each body separately from scratch. In this part of video, it shows how to create geometry using various geometry commands like Sketch, Pull, etc. Keywords: Pull, Assembly, Move, Sketch
1. 2052813.zip
2. 2052813_Captions-EN.mp4
