ANSYS SpaceClaim Direct Modeler: Reverse Engineering – Skin Surface: Creating Boundary Patches from an STL
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2043786.pdf
2. 2043786.zip
