Tagged: 17, ANSYS SpaceClaim DirectModeler, General, spaceclaim, stl, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2043798.pdf
2. 2043798.zip
