May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim allows to import the point data directly from a text file and also creates curves using those points. Later we can use those curves for further geometric operations to create required geometry. Keywords: Point Data, Import Points, Insert File
1. 2052816.zip
2. 2052816_Captions-EN.mp4
