May 15, 2023 at 8:32 am
SolutionParticipantIn SpaceClaim, you can create 3D curves passing through various references. It can be straight line as well as spline. Later on, you can use these 3D curves to convert them to solids. Keywords: Curves, Insert, Cylinder
1. 2052820_Captions-EN.mp4
