April 13, 2023 at 7:33 am
SolutionParticipantPlease refer to the attachments to access the video recording of the webinar and the slides used for the presentation. Note: Please use Windows media player instead of VLC media player to avoid issues with playing the video file.
1. TipsTricks_STL_Oct28_2019.pdf
2. Working with STL files in SpaceClaim-20191029 1401-1.mp4
