June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video demonstrates how a structure undergoing rotational forces generates noise due to vibration. The rotational forces are applied on the structure in a mode superposition Harmonic Response simulation. The structural velocities are then transferred to a Harmonic Acoustics simulation that produces an acoustic signature.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
