March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the video recording of the webinar and the slides used for the presentation. Note: Please use Windows media player instead of VLC media player to avoid issues with playing the video file.
1. Tip and Tricks_Explicit Dynamics.pdf
2. Using Explicit Dynamics to Improve Product Design-20191008 1401-1.mp4
