Tagged: discovery-aim, discovery-live, How To, installation, spaceclaim
September 26, 2022 at 9:53 am
FAQParticipantError type: ANSYS Licensing Error while launching Discovery products
Error Message: ANSYS Licensing Error
FlexNet Embedded Action: FNE Checkout -> Acquire License
FlexNet Embedded error: [1,7E1,8,0[7000004A,0,701A4]]
Trusted storage hostid does not match system hostid
Solution: Release License Activation as follows:
- Launch the Windows Command Prompt from the start menu by entering “cmd” into the search field.
- In the command prompt, type in:
cd C:Program FilesANSYS IncShared FilesLicensingwinx64
- Once in that directory, run the following command:
ansysls_client -DeactivateAllEntitlements
- Then re-run the software and activate by logging in with your Discovery account credentials.
A successful deactivation can be confirmed as below:
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
