May 11, 2026 at 3:37 pm
SolutionParticipant
FreeFlow FAQs & Tips
Welcome to Ansys FreeFlow FAQ and Tips Center.
Navigate through contents below and find answers and tips from our team of experts to enhance your Ansys FreeFlow engineering simulations.
/FreeFlow SPH Adaptive Size
What is SPH Adaptive Size in Ansys FreeFlow?
SPH Adaptive Size is a capability in Ansys FreeFlow that automatically adjusts the size (resolution) of SPH elements during a simulation… Read full FAQ
How is SPH Adaptive Size different from standard SPH in Ansys FreeFlow?
With SPH Adaptive Size, the element size can change locally during simulation, the resolution is higher only in selected regions or near boundaries… Read full FAQ
How does SPH Adaptive Size work in Ansys FreeFlow?
SPH Adaptive Size in Ansys FreeFlow works by refining and coarsening SPH elements in a controlled, hierarchical manner, improving accuracy only where needed while keeping overall computational cost low… Read full FAQ
What are the main benefits of using SPH Adaptive Size, and what types of applications benefit most from it?
SPH Adaptive Size key benefits include, Improved accuracy in critical flow regions, Reduced computation time compared to uniform fine resolution… Read full FAQ
Which solvers support SPH Adaptive Size?
SPH Adaptive Size is supported with the following solvers, Implicit Incompressible SPH (IISPH) — Default and recommended solver… Read full FAQ
What is SPH Adaptive size coarsening, and how does it work in Ansys FreeFlow?
Coarsening is the process of reducing SPH resolution when refined elements are no longer needed… Read full FAQ
What are the limitations of SPH Adaptive Size in Ansys FreeFlow?
SPH Adaptive Size in Ansys FreeFlow has a few important limitations that users should consider when setting up simulations and analyzing results… Read full FAQ
What happens to SPH elements during SPH Adaptive refinement in Ansys FreeFlow?
When an SPH element is refined: It is replaced by smaller elements according to the selected refinement level…Read full FAQ
How do I define where refinement should occur with SPH Adaptive size in Ansys FreeFlow?
Ansys FreeFlow provides three approaches for defining refinement regions…
Read full FAQ
- Skewness in ANSYS Meshing
