March 17, 2023 at 1:12 pm
Solution
ParticipantPlease see attached example. Force excitation is not supported in Mechanical interface and command snippets have to be used in Mechanical. The procedure is well explained in ANSYS Help: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/ans_str/Hlp_G_STR6_8.html?q=Performing%20a%20Random%20Vibration%20(PSD)%20Analysis
1. 2056532.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
