June 6, 2022 at 9:57 am
FAQParticipantRemoving SE results with OUTRES is not enough since SE geometry is still included into the rst file; Use RSPLIT command to remove SE from the results and from the geometry info contained into the rst file (The subset geometry is also written so that no database file is required to postprocess the subset results files. You must not resume any database when postprocessing one of these results files)
ESEL,U,ename,,matrix50 ! unselect superelement
RSPLIT,ALL,ESEL,myreducedrst !create new result database
