May 15, 2023 at 8:32 am
SolutionParticipantUsing SpaceClaim, models and its features can be quickly aligned. Attached video shows how to align holes on 2 plates. Keywords: align, holes, move, drag
1. 2052858.mp4
2. 2052858.zip
