Additive Print: What is the difference between the material properties “Powder Absorptivity” and “Solid Absorptivity” in Additive Print? Which material property controls the thermal influence of the unmelted powder?
May 15, 2023 at 8:32 am
SolutionParticipantPlease see the attached document to access the solution.
1. 2056199_Solution.pdf
