April 5, 2023 at 2:32 pm
FAQParticipantThe results folder can be changed only by following the steps below: 1) Close the application. 2) From a windows terminal run these two commands: move %appdata%ansys-additive
mklink /j %appdata%ansys-additive 3) Start the application again Note that the Additive Files are located in the folder %appdata% => ansys-additive/minio.
