[Additive Print]: Are there any tips on the quality of the initial STL file needed to compensate a geometry?
May 15, 2023 at 8:32 am
SolutionParticipantPlease see the attached document to access the solution.
1. AM%20ANSYS%20-%20Compensating%20Geometry%20Additive%20Print.pdf
