A Shock absorber is represented as spring element with damping constant. Modal analysis is performed using Reduced Damped (QRDAMP) solver. How to perform a Modal super position harmonic or transient analysis further ?
June 6, 2022 at 9:58 am
FAQParticipantFor a MSUP (mode superposition) Harmonic Analysis and a MSUP Transient Analysis, one can use the Reduced Damped (QRDAMP) solver with the “Store Complex Solution” property set to “No”. In this case, regular (non-complex) mode shapes are calculated and are used for mode-superposition. Although complex frequencies are used for mode-superposition, regular (non-complex) frequencies are reported in tabular data.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
