Tagged: 2021 R2, Analysis (HFSS), hfss, Remote/Distributed Solving
January 31, 2023 at 9:25 amFAQParticipant
Windows のアクティブディレクトリ (ドメイン参加) 環境の場合、全ての分散計算端末で以下のシステム環境変数を設定する必要があります。 名前: I_MPI_AUTH_METHOD 値: delegate
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [info] A variation (変数条件) has been requested using the following machines: Local Machine
