September 22, 2023 at 11:02 am
SolutionParticipantSometimes when you run a simulation you are not able to read all the sentence in the Progress Bar. In this case it is needed to increase his size. This solution shows how to do it. Keywords: Maxwell, User Interface, Progress Bar Please refer to the attachments to access the Solution.
1. EM_FAQ_How%20do%20I%20make%20the%20Progress%20Bar%20bigger%20in%20Maxwell.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- EM FAQ: How to define project variables that apply to all designs?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- What are the default boundary conditions in different solvers?
- Vacuum Thermal Modeling in ANSYS Icepak
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
