Tagged: 18.1, General, mechanical, structural-dynamics, structural-mechanics
August 25, 2023 at 12:16 pm
SolutionParticipantPlease find attached an example based on VM203 created in Workbench Mechanical 17.0 that demonstrates pressure PSD loading. (It is not the same as VM203 since all the rotation DOF constraints are added.)
1. 2050835.pdf
2. 2050835.zip
