My structure’s first natural frequency is slightly less than the starting frequency of the PSD spectrum. should i go for random vibration analysis?
August 25, 2023 at 12:16 pm
SolutionParticipantMy first fundamental frequency is 47 hz. and my PSD data end at 45 hz ..should i go for random vibration analysis..? As the 1st natural frequency is very close the one of the excitation frequency, dynamic magnification is expected. However, the amount of dynamic magnification depends on the damping and direction of excitation and mode shape. If the excitation direction is same as that of the mode shape, then there would be considerable magnification. So it recommended to do a PSD analysis.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
