August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: numerical beach, damping
1. 2050521.pdf
- Guidelines for Courant Number for steady and transient simulation.
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
