Tagged: 14.5, dynamic-meshing, fluent, fluid-dynamics, General - FLUENT
August 25, 2023 at 12:15 pm
Solution
ParticipantThere are times when the error in Figure 1 appears while using the Layering function of MDM: In this case, you can check whether the mesh that has moved through Display->Mesh … For example, in Figure 2, you can see that the movement area is slightly sinks to the stationary area. In such a case, you can work around the problem by performing a treatment, such as reducing the time step size.
1. 2041777.pdf
- Skewness in ANSYS Meshing
