Tagged: 18.2, fluent, fluid-dynamics, General - FLUENT, post-processing
June 5, 2023 at 7:06 am
FAQParticipantStarting with ANSYS Fluent 18.2 this is no longer supported. As workaround, you can revert to a different serial version by starting Fluent with the option -t0 that still supports this export option. Note that this version of Fluent will be dropped in a future release.
- Skewness in ANSYS Meshing
