My multicomponent real gas simulation won’t converge. What is one of the first things I can look at in order to move forward?
Tagged: 18, BCs & Interfaces, fluent, fluid-dynamics, materials, Species/Reactions
June 5, 2023 at 7:06 am
FAQParticipantApart from the usual solver settings and best practices, which are documented, one of the next most common errors is using the real gas law for all components when only one gas is actually in the real gas regime. It may be possible to model only one component with real gas properties and handle the rest with the ideal gas law. This will enhance the stability of the simulation, because there is no real gas table interpolation or table or cubic equation of state for the ideal gases.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
