[error] Refining meshes, reconciling multiregion mesh component IDs and overlaps, process mesh3d : subprocess %3 exited with save.
Tagged: 18, HFSS - SYS, hpc, HPC/Parallel, Installation/Licensing/Systems
June 5, 2023 at 7:05 am
FAQParticipantError occurs when a space is embedded in the temp directory. Open Programs and Features in the Windows control Panel, highlight “ANSYS Electromagnetics Suite 18.0”, select “change” option to open the Modify/Repair/Remove menu. Select “Modify” When specifying Temp Directory, specify a path that does not contain a space. ex: C:Scratch.
