June 5, 2023 at 7:05 am
FAQParticipantIf, upon opening CFD-Post in WB, an error window is generated saying “No locators provided in location parameter”, it indicates a plot or other user-defined object was set up in Post that uses a variable not defined on the region to be plotted. Changing the region in the plot object to one where the variable is defined will resolve the issue.
- Skewness in ANSYS Meshing
