June 5, 2023 at 7:05 am
FAQParticipantIn CFD-Post, you can choose a perspective view or orthographic. Selection method is as follows. First, right click the button in the window of the View you want to switch the display method, to display the menu. Hover the cursor to the menu of Projection, choices will appear, to select it and click the left mouse button Orthograhic or Prespective.
- Skewness in ANSYS Meshing
