Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantOne can not use worksheet to insert user defined results before solving the model. That’s why worksheet is grayed out. After solving the model, you will be able to use worksheet. If you know the expression of the user defined result, you can also right click on ‘solution’, insert a user defined result and enter the expression.
