Why isn’t the stress-strain response from response function hyperelastic model not matching with the input stress-strain curve?
June 5, 2023 at 7:04 am
FAQParticipantThe experimental data is engineering stress-strain whereas the stresses/strains calculated by ANSYS are true stress and strain. Either of these quantities should be converted to the right format before making comparison.
