June 5, 2023 at 7:04 am
FAQParticipantTo bond two shell parts with gap, use a “Maximum Offset” for the bonded contact larger than the gap. From Tree Outline, find the Contact, in “Details of the Contact”, set a “Maximum Offset” value for “Definition”
