Structural & Thermal
How to apply different initial temperatures for different parts/materials?
    • FAQFAQ
      Participant
      Different initial conditions for each material/part can be applied using IC command. IC command specifies the initial condition for preselected set of nodes. One can also use the component to specify the initial conditions. More details about the IC command can be found in Help file: help/ans_cmd/Hlp_C_IC.html
