Tagged: 16.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantNo. When connected on the project schematic, Mechanical needs a ds.dat file to fully communicate with DesignLife. The model must be solved in Mechanical to create the ds.dat file. You can use the standalone DesignLife to access a file.rst that was created in MAPDL.
