May 25, 2023 at 7:30 am
SolutionParticipantWhen high accuracy solution is sought in application with very non-linear B-H material behaviour, using a setup with too small setting for the residual may not always work. Attached document explains another approach for obtaining accurate results. Keywords: convergence, speed up, time, BH
1. 1837_Using_variable_residual_value.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Cloud Computing from Electronics Desktop
- What are the available boundary conditions in Maxwell?
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
