Tagged: Electromagnetics & Electronics, hfss, modeler
May 25, 2023 at 7:30 am
SolutionParticipantDesigners often use bondwires to make a connection from the package to the Integrated Circuit (IC). See the attached pdf document for step-by-step creation of bondwires in HFSS 3D Layout.
1. Bondwires%20creation%20in%203D%20Layout.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- How to Create Bondwires in 3D Layout ?
