Licensing
Licensing
Discovery: Resolve instcore.exe error during installation
    • SolutionSolution
      Participant
      Error while installing Discovery products: instcore.exe has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. Solution: Below suggestions help to overcome this error: – disable antivirus scanners during installation – make sure to extract the downloaded .zip file before attempting to install
