Why do the value of A mentioned in the “thermal No PDF” reaction from the reaction libraries is half of the value mentioned in CFX theory guide?
Tagged: 19, cfx, Eddy Dissipation, fluid-dynamics, Species/Reactions, thermal NO model
May 15, 2023 at 8:32 am
- How do I model humidity in Fluent?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Configuring and Solving the Chemical Species Transport in Fluent
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
