In Additive Print Product, are there any instructions for simulating parts attached to the baseplate with minimum support height=zero?
May 15, 2023 at 8:32 am
SolutionParticipantWhen you simulate a part directly on the baseplate with minimum support height set to 0, there are variations in the assumptions at bottom of the part depending upon the outputs a user selects. Varying combinations of “Simulate Part On Baseplate without Additional Supports” and “Displacement After Cutoff” settings result in different assumptions. The attached article describes the different assumption variations.
1. Simulating%20parts%20with%20support%20for%20Additive%20Print.pdf
