May 15, 2023 at 8:32 am
Solution
ParticipantAttached video shows how to extract and edit a mid surface. The process demonstrates mid surface tool, removing and moving holes in extracted midsurface and mirroring. Keywords: mid-surface, move, mirror
1. 2052853.mp4
2. 2052853.zip
