May 11, 2023 at 1:02 pm
SolutionParticipantIn previous versions, losses are usually reported as the total loss of all objects. To obtain losses on a certain object, we need to use field calculator to integrate the loss density over the object volume. This document demonstrates how to enable object-based loss report on individual objects in Maxwell 2D&3D transient starting from 2021R2. The supported loss will be solid loss and core loss.
1. EM_FAQ_Maxwell_How to Report Per-object Loss.pdf
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Cloud Computing from Electronics Desktop
- What are the available boundary conditions in Maxwell?
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
