How to define non-linear spring in ANSYS for a given load deflection curve for given load deflection curve and validate it with its result?
Tagged: 2022 R1, General, mechanical, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantPlease see attached document for same
1. 2063773.pdf
2. 2063773.zip
